thepremier
- Dec 31, 2005
Early this summer I had overheating problems, and it was quite obvious that the problem was that I needed to replace a bad water pump because the leaking water was coming straight from the water pump.
I replaced the bad water pump with a brand new one, and the car has been running fine for months now... Today I was driving, and my Scanmaster had a Mal Code 14, and I found out that it indicates that the coolant sensor is reading high.
I pulled over into a gas station, and it was evident that the car was hot... Let it sit a while and added some coolant & water, after that everything seemed to be fine until I got home and noticed that there was water leaking under the car.
It wasn't coming from the water pump area, but when I looked under the car where the puddle was located, the water was dripping from the crossover pipe near the oil pan...
I'm not quite sure where that leak could be coming from, has anybody experienced this type of issue? Any help would be greatly apppreciated.
Thank You
Thank You
