Concert Sound
SmooveG
I now have concert sound lower door panels, what else do I need in the door to make these work. before the outage someone said I need cages for the speakers, also this is not a stock intstall so no need for speaker wires.
Will I need to make a hole in the door, I haven't removed my door panel yet.
Thanks G
P.S. sorry for the other post, I can't seem to edit it
Thanks G
You will need a shallow 5.25" speaker for the doors. I don't know for sure if you need to cut out anything or need the stock mount for the speaker since you don't have the concert sound doors.
Also no wires so you will need to run it to the deck.
Cutting holes for Concert Sound
You do need to cut holes in the doors to make the Concert Sound fit. The speakers will not fit otherwise, and if you try to mount them where there already holes in the door, they will interfere with the window operation.
It's worth the trouble though.
