WildGS
- Nov 27, 2007
I have 2 turbos sitting here and would like some opinions on what differences I could expect between one or the other.
Reason I am asking is no one has really run the GT35 on a 3.8 and I am not sure what to expect. Not that I expect anyone to know for certain, but the biggest difference I can see being a newb is the turbine wheels.
BTW this is a FWD 3800 setup if anyone is curious. ;-)
(NOTE: these are measurements I took so they will be close not sure how correct they are)
Turbo #1 (left)
GT3582R
Ball Bearing
Water cooled
Compressor cover -- 4" inlet, 2.5" outlet, .70 A/R
ID -- 06261
Compressor wheel
Inducer -- 66.3mm
Exducer -- 84.1 mm
Turbine -- T4 inlet, 3" v-band outlet .68 A/R
ID -- TH6835R
Inducer -- 67.81mm
Exducer -- 62.32mm
Turbo #2 (right)
T67
Journal Bearing
Compressor cover -- 3" inlet, 2" outlet, .60 A/R
ID -- CCE67
Compressor wheel
Inducer -- 66.67mm
Exducer -- 84.00mm
ID -- TH6876A
Inducer -- 73.84mm
Exducer -- 63.84mm
Turbo #1 (left)
GT3582R
Ball Bearing
Water cooled
ID -- 06261
Compressor wheel
Inducer -- 66.3mm
Exducer -- 84.1 mm
ID -- TH6835R
Inducer -- 67.81mm
Exducer -- 62.32mm
Turbo #2 (right)
T67
Journal Bearing
ID -- CCE67
Compressor wheel
Inducer -- 66.67mm
Exducer -- 84.00mm
ID -- TH6876A
Inducer -- 73.84mm
Exducer -- 63.84mm
