Comp 206
tacordes
I want to get a comp 206/206 flat tappet cam and lifter kit.
The part number I think is CL69-234-4. I've been doing alot of searching and when I think I have the right number the are a few post that are saying this part number is a NON turbo cam. ??????
Please help me...... I want to order a 206/206 cam for my 87 GN
If you HAVE to have a FT cam, and I use one myself, just call T/A or Full Throttle and they'll hook you up. Most places don't stock them and none warranty them, so most, even vendors, will try to talk you out of it. It'll work with easy ramps, good but not aggressive springs, and the right break in procedure and a steady diet of ZDDP at oil changes. I have 20k+ miles on my FT cam and probably 100+ passes. It works fine! I got my Erson through T/A with 75lb springs fwiw. I ran today 11.71@117.78 through the exhaust with 22psi TC open and 25psi TC locked. I ran times in my sig at 28+psi @ BG last year; same setup otherwise and drove it there 600 miles each way. FT cams can last and work.
