I've borrowed a front coil spring compressor from a friend of mine and I have a couple of questions.
When the spring is compressed the threaded shaft that the hooks are on is too long and I cant install the spring. Is this threaded shaft supposed to pass throught the hole in the frame that the top of the shock passes through? If so then the the problem I have is that the shaft is bigger than the shock hole. Am I doing something wrong here or do I need to find another compressor that has a narrower shaft?
TIA
TIA
