Hey guys sent my FAST ECM to Brian at Comp Cams last week. Well its not good,he saids theres a part that bad and doesnt have replacement parts for it. I have a backup one that on the car and its running good at this time. The problems that I was having is the green idle bubble would flat line on the tables. Fixed that problem by re-installing the CCOM and then the idle bubbles would float around the tables as it should. Then the car would idle great and drive fine and all of a sudden the it would start to lean out and pop like a freaking cannon. The RPM's would start acting weird. I put the backup one and its been good and perimeters are on the money. So I was told that a fellow member named Craig is good with these ECM's. Can one point me his way.
Thanks,
Eric
Thanks,
Eric
