CK Performance Shift Recalibration Kit
TurboJoe3.8
Senior Member
CK Performance Shift Recalibration Kit #24RSK/A.
NEW IN BOX.
$100 shipped in the lower 48 states- paypal add 4%
Description below courtesy of CK Performance website:
SHIFT RECALIBRATION KIT #24RSRK/A $139.99
The main focus of this kit is to reduce clutch and band slippage common with the factory hydraulic calibration.This easy to install kit includes all the necessary parts to recalibrate the hydraulic circuitry of the GM2004R transmission for high performance street and dragstrip usage.New .500" TV boost valve,and .296" intermediate boost valves and a heavy duty pressure regulator spring significantly raise transmission mainline pressure to increase clutch and band apply pressures. A new custom designed CKPERFORMANCE seperator plate is included to increase the flow of oil to the friction elements as well as delete unneccessary circuits . Re-engineered springs for the accumulator valve,line bias,1/2 accumulator ,and 3/4 accumulator,and an updated 3/4 accumulator piston introduce a throttle sensitive accumulator and pressure rise system that meets the demands of high output engines.This reduces friction element failure and excessive heat build up during and after ratio changes.This kit allows the shifts to get shorter and firmer as the throttle is opened,resulting in clean ,positive gear changes at all throttle angles Most kits do not have this feature engineered into them resulting in brutal part throttle shifts that beat and break internal components as well as generate many new drivability complaints.Hundreds of these kits are in use and this kit is recognized as the best of its kind.includes all the necessary gaskets and instructions.Please note that high performance applications will benefit from the use of a larger intermediate servo to multiply the clamping force applied to the intermediate band.If your transmission is not from an 86 / 87 Buick Grand National or 89 Turbo Trans Am which was factory equipt with a high performance intermediate servo assembly,the use of a high performance servo assembly should be considered.
Thanks,
Joe :)
NEW IN BOX.
Thanks,
Joe :)
ill take it, pm sent
