Thanks for the help, here's what I figured out.
KC valve body with medium weighted gov, shifted way to early, had NO downshiuft with throttle. I thought it was a TV issue but we had good pressure and rise.
Installed the CR valve body, same gov, did the 3-2 valve trick. Still shifting way too early, plus now I had a weird issue with the lockup, had lockup in 2nd and 3rd and not in OD.
I didn't ride in the car before the work, so didn't have a comparison.
With the super early upshifts I couldn't figure out the lockup issue, and with the lockup issue I wasn't sure what was going on.
then I remembered I had swapped VB's and not swapped the damn 4th gear NO pressure switch onto the replacement VB. Dropped the pan, installed the correct pressure switch and a BR/CZ type governor and it was perfect.
Shifts were about 5800 at WOT, firm, crisp, good part throttle and kicdown manners, no harsh 3-2 downshift. That seems to have cleaned up with the 3-2 mod. Customer commented on it and really liked that.
Mine aren't harsh because I retain the cushion spring, but that mod makes it even less, barely noticeable.
Thanks again.
Thanks again.
