LilSpann601
- Jul 13, 2008
is there anyway to check the waste gate and the actuator?
The vacuum side (plumbed to the plenum) will most likely leak and should be capped off - it doesn't do anything. The pressure side is connected to the compressor foot - if it won't hold vacuum, it won't hold pressure.
A leaking actuator will lead overboost. If you're not seeing enough boost and want to rule out the wastegate actuator, you can clamp it closed with a turnbuckle or heavy wire - but watch the boost gauge and don't get carried away.
well i went ahead and cab the wastegate actuator vaccum side going to the back of the plenum i guess the pressure side...i left the other vac on the wg actuator which is going down to the elbow is this correct ???
ok...as for the rear i havnt decided on it yet....It makes better sense now. Yes the line furthest away from the wastegate goes to the "foot" of the turbo. It's the presure side so you should be good. What did you decide on the rear? I forgot to tell you to get a higher stall convertor, around 1800-2k should do great. A little looser convertor will help spool the turbo and give you the tire burner you want. And you may not want to change the gears then.
Go to the tranny section and do some searches. If that doesn't help PM Chris718 or Brian Hofer and see what they suggest as far as stall speed. The 83 T Type had a higher stall speed but also had the 2004r. If you increase the stall speed you should be able to offset for the high gears in the rear so you might not want to change them.
where can i get the right tq convertor...i searched ebay i actually dont know what to look for i know what a torque convertor is but where can i get one that will fit with my trans i dont know whether my trans is a 350 or 250 or 200 metric...i assumed it was a 200 metric but when i bought the detent cable the one for the 350 worked...oh yea the first trans i had was a 350 but i got a trans for 100 out of a 85 cutlass na v6 thats the one im using now
