I have a mostly stock (bolt ons) 86 ttype. I am interested in checking my stall speed as I am suspicious of whether I have a stock D 5 or a replacement. When visually inspecting converter, I do see the D 5. However when checking the stamped D 5 with the picture over at GNTTYPE.ORG it appears to differ. On mine, the D and the 5 are not stamped the same size. The picture on website shows both the D and 5 stamped same size/height. Should I be concerned? Car does seem to have a bit of lag from a standstill for a stock turbo. I think I read some where that you can test your stall speed by applying the gas while holding brake pedal until you just reach into boost or until tires start to spin. Upon doing so look at tach (scanmaster preferred) to check the rpm at which it occured (tire spin) to gauge the stall speed. Any ones help with this would be much appreciated! :smile:
