Turbostangman
- Oct 16, 2001
I wired up a Check engine light and ALDL Port on a Kit car that has a 84 GN engine transplanted into it. I wanted to check the codes to see if I could find a miss that has plagued the car since I got it running.
I wired up the ALDL port as follows to the wires going to the 434 connector off the ECU harness;
ALDL Terminal..............434 Terminal
Pin A............................Grnd
Pin B wht/Blk...........Wht/Blk Pin E
Pin D Brn/Wht..........Brn/Wht ECU Pin A5 (spliced with wire to CEL)
Pin E Orange.............Orange Pin J
Pin F Tan/Blk..............Tan/Blk Pin H
Pin H Grey..................Grey Pin D
The other side of the Check Engine Light (CEL) is wired to a ign 12v source as shown in the main wiring schematic.
The problem is when the key is turned to the on possition the CEL comes on and stayes on. When I jump terminals A & B it doesn't do anything, it just stays on.
Did I do something wrong or is something else going on?
Someone PLease help!! I am getting SO AGGRIVATED!! and I need this fixed ASAP!!
Does anyone have any idea what is going on?
