changing injectors
Larry
I have 83# injectors.. running 66-68% duty cycle.. Id like to change to 72#.. What do I need to do in changing my program set up on my speedpro?? Thanks Larry:confused:
First, just change the injector flow rate setting in the Fuel Calculation Parameters screen. This should cover most of it. You may need to tweak your VE table a little bit, but this should be a very painless change. The speed/density calculation takes the injector size into account, so simply changing this value should land you pretty close to where you were.
Craig
The only other thing I can think of is that you also might want to re-adjust your starting settings, since this is in inj ms and not a calculated fuel-flow number.
(If you run a dry nitrous system then you'd want to re-adjust those #'s as well, since they are also in inj ms)
-Bob Cunningham
bobc@gnttype.org
