Caspers knock sensor
mzunino
Took out my GN for a blast a/f showing 11.2 at wot but knock sensor flashing to red. It's making 533 rwhp been told cant trust them when making that much hp. Is that true? Brand new wide band sensor, scanmaster 3 shows no knock. Running a dual nozzle alky kit also
Are you hearing detonation? Can you feel the car pull timing when this occurs?
Sent from my SPH-L720 using Tapatalk 4
Sounds like someone threw a handfull of nickels at the block.
No neither of those things happens it keeps pulling
What about knock counts on the scanmaster
Possibly picking up false knock? Check your down pipe to frame clearance. Hows the ds motor mount?
