turbo96max
- Jun 6, 2007
So I made it out to the track after years of messing with the car . It finally made some clean passes.
e85 120# 26-28 psi on the gauge
on old 17 inch street drag radials and 0 vac launches made 11.3 @ 123 w 1.98 60ft.
I noticed something ODD. The caspers gauge was turning RED on pretty much the whole pass. but the PL did not pick up any knock not did the chip pull any timing.
I am not familiar with the knock gauge as it was installed when i got the car.
Are they both using the same sensor to track knock?
I noticed a sensor on the intake manifold and one on the back of the block? Can anyone tell me what each sensor does?
Reason im investigating is bc knowing about plenty of guys running more boost. I turned the boost up to 32-33 psi on my last run . The log looks clean , no knock, afrs 11.3s with one weird spike where it leaned out for one frame rate which im thinking is just an error in the tool, but the gauge did the same thing pegged red , and that pass at 33 psi I blew a headgasket. Last cyl on the passenger side.
any thoughts?
any thoughts?
