whats your issue
hopefully you have the right standoffs , spacer , passenger bracket and bolts.
install the new longer bolt with washer pushed through the upper bracket hole , then put short spacer on the bolt (or use washers about 1/2" total) , put thread sealer on the threads and then install into the pump.
