Carrillo Rods
drturbo69
NEW-OFF CENTER 6.427-237 BIG END 8.43 THICK 8.25 PIN .WAS GOING WITH EAGLE CRANK STOCK BLOCK AND CUSTOM PISTONS.
900.00 SHIPPED.
THANKS FRANK
More info please
Frank,
I hate to tell you this but your #'s don't make any sense.
I believe what you're saying is that the rods are 6.4XX" long with a .843" big end thickness but the rest is very confusing. Are the rods .940" pin dia (Buick) or .927" pin dia. (SBC) ?
Neal
I think he means the big end dia of the rod is 2.37 (book specks are 2.3738"-2.3745") The length is a odd ball but could well be 6.427 The 8.25 pin has me:confused:
9sec.
Sent you a e mail Frank.
RODS
THOSE ARE THE SPECS WAS GOING TO USE IN STOCK BLOCK. I KNOW PINS ARE SMALLER-THESE WERE OLD INDY-LOTS OF BOOST-WILL REQUIRE CUSTOM PISTON.SHOULD WORK WELL WITH EAGLE CRANK-STOCK BLOCK.
FRANK
Re: Re: RODS
OPEN TO TRADES NEED DUTT. OIL PUMP 90MM T.BODY ON CENTER INTAKE BGC BRAIDED HOSE AN FITTINGS.ALSO OFFERS?
THANKS FRANK
Believe it or not I have a set of custom 3.960" CP pistons (8.75 c/r) that will fit that length rod and a stock deck height. They were in a short deck block 9.420" with a 6.3" rod and a 3.625" crank. The pin is .927"
Jeff
