Blow thru is the way to go.
Honestly,
I wil admit that im SUPER F'n biased to the drawthru, only because im obsessed with making people cry with inferior $hit. makes me feel good.
But blow thru isnt really cheaper than a factory draw thru setup per say, but will make 3 times the power is you pay attention to what your doing. It all boils down to one key element.
INTERCOOLER!
As we all know, that charge coming out of the turbo is cookin' and is doing the same thing to the inside of your engine, Going blowthru allows you to use a factory 86/87 intercooler. or bigger, if the power demand is out there.
so for what you need? heres a list.
86/87 exhaust manifolds and exhaust. down pipe is of your choice. THDP is worth the money
86/87 turbo.... or others depending on desired power level.
86/87 intercooler..... or others depending on desired power level
86/87 cam, or comparable grind. or others depending on desired power level
edelbrock intake. the wieand is OK, but not that great on the bottom end. **UNLESS** you have the old skool one like Adam.
demon or holley blow thru carb. 550 to 650 CFM. mods can be done on a regular one if you have the mechanical kno-how.
electric fuel pump. can be stock 86-87 in-tank unit, or aftermarket pump. just insure adequate fuel volume and or pressure suited to the level of performance desired.
boost referenced fuel regulator. as your blowing thru the carb, the fuel pressure will have to rise on a 1-1 or I like a 1.32-1 ratio with boost. this keeps metering accurate for various boost levels.
Timing control. there are many ways to do this, 79 style ESC box, work on knock alone, while a MSD boost timing master will retard spark in relation to rise in boost. both are excellent systems. I like to personally use BOTH at the same time! no more blown motors for me!
umm......... what else? i reckon thats basicly everything you need.
:biggrin:A.j.
