daily driver
- Oct 3, 2005
I am in the middle of a no-start situation
Here is my question, my car started losing throttle response, was idling rough, and then died while idling and would not restart. When I got it home and started checking it out I found the coilpack looked liked it had melted down (pic should be attached) There is material coming out of the side of the coil and the adjacent wall is bowed out. It was supposed to be a new GM unit (bought from board member) and it had had been running fine for a few weeks.
I also found a firewall ground that was not completely tight so I fixed that and installed my known good coil. I still have no spark so I am wondering if the module is bad after all. Is there a way to check my module that is on the car to confirm it is bad? I have an new Duralast ign module to install but I want to check it right and not just throw parts at it.
