car stopped running
lee humphrey
L HUMP
86 ttype stage 2 motor was driving running fine. then stopped at light pressed the gas car died wouldn't start check and change module and coil crank sensor check ecm bob check it out it ok car still not running.check tps sensor and change. made sure cam sensor was tight and correct.checked fuel pressure fine
Check fuses??
Key on verify power on pin P and M (pink/black wires) on the module plug.
Rick
Mine did the same thing and it was the CCCI fuse. It's near the top left side of your fuse block.
