I say "cold" because it will stall randomly untill you drive it for a while, it will sometimes still stall randomly, but if you drive down the highway it will never stall after this. I drive 10 minutes to get on the highway and today it stalled twice, I had stop and go traffic after being on the highway for 10-15 minutes and it never did it once.
now it only does it coming to a stop, usually about the time is drops to first, and when taking off. if you really ease into it its usually ok, but it you take off normal it will start to go then stall. but it always starts right back up.
I just replaced the iac, and I had a code 15 so I did the temp sensor. the last couple days the check engine light has come on whle i let it warm up leaving work, but it went off as soon as I started driving, now I have a code 45, but only at cold idle.
I drove around town the other day for like 20 minutes after warming up and it stalled 5 times, it sat at a show for a few hours and ran perfect after that.
I still have the origional maf and map. and I dont know whos chip it is, I have 50 lb injectors and the chip says 22 degrees also
I know this is a lot and any suggestions are welcome, I do not have a scan tool or monitor.
let me know what you think.
