Well I was driving my Buick home last night and it cut out on me at a light and took like 10 seconds of cranking to get home, I also had to brake it and hold the gas to keep it goin at the lights. When I got home and shut it off i could hear the coolant boiling over in the reservoir, so I pull out the scanner...255 Degrees!!!!!
The car had a new radiator when I got it, it looks like a pretty thick one. but it is black and also has an external oil cooler for the trans. So I am guessing its a Camaro version. I also have a FMIC as well. SHould I start with a thermostat to see if that helps? Im worried ill do some serious damage if I drive it.
FWIW I was driving in about 85 degree heat with A/C on. I don't know how long its been doing this. It has done the thing where it stalls out before but I never heard it boiling over. It also would smoke randomly, sometimes going days or weeks with nothing and then sometimes it'll smoke a little bit just at idle. Not sure if its related or not
