My car runs 12 sec 1/4 so pretty mild with stock converter. Trans is also stock as far as I know.
Lately, when I run it hard, full throttle, the shift to 2nd is mush. If I run it half throttle, it will sometimes chirp or at least a solid shift with a jolt.
Anyway, when the trans was strong, the car would break the tires loose when shifting to 2nd at WOT. When we had a housefull of guests for a holiday, I adjusted the TV cable a notch or two for softer shifts. There was maybe 1000 miles total put on the car with the softer shifts.
Now I put it TV back and the mushy WOT shift to 2nd. Did I burn/wear out the bands? Trans is 1/2 qt over full as usual. Fluid is fresh and smells good. The trans shifts fine for normal driving. Very firm and responds to the TV cable position.
Is there anything I can do before I head to the trans shop to improve the WOT shift?
