I'm beginning to tear down a 60-65K mile longblock that I got out of a local wrecked GN. While tearing apart, I found that the #3 exhaust lobe is partially wiped. I will be rebuilding this engine, basically a re-ring and re-bearing job because everything still checks out good. Of course, I will be installing a new cam and this is where I have questions. Unfortunately, a roller cam is not in the budget. I will be installing either the 204/214, Comp 206 (Weber), or something else comparable. Since this block has wiped a cam before, is there anything that I can do to help prevent excessive wear on the new rebuild? Everything is apart so now is the time to do anything helpful.
The alternatives that come to mind are:
1) break in the new cam/lifter as normal (not much one to HOPE it doesn't wipe)
2) cryogenic treatment of the cam and lifters to harden both surfaces.
3) use either the "cam saver" or "cool face" lifters to help oil the cam better
4) bush the lifter somehow to help the alignment over the cam lobe.
Please give me some opinions and any other ideas that will help.
