I will be changing out my cam sensor to a new GM sensor this weekend and would like to know what all I will need to remove from the car to do this repair. Would a distributor wrench help with this repair? If so what size is the hold down bolt 9/16 or 1/2 ? About how long should this repair take?
Also if anyone knows of a HOW TO on this repair. I have read the info on a few web sites, But none of them say what to remove from the car to be able to replace the sensor. I have the Caspers cam tool so that I can set the sensor once it is in place. The car runs now with no trouble (cam sensor is tapping) so if I removed the old one and put the new one in the same way would it not run just the same other than the tapping? That way I wouldn't need to set the sensor?
Thanks for any help.
