E ericttype Member Joined Nov 22, 2009 Mar 14, 2013 #1 cam sensor tool casper $35.00 used coil pack & module working order $75.00 used a/c lines no holes good shape $125 snew J&e stroke pistons 5.970 rods with rings $525
D dalton Member Joined Jun 27, 2001 Mar 14, 2013 #2 Interested in coil pack and ignition module. Money order ok i'll need you address. Thanks
E ericttype Member Joined Nov 22, 2009 Mar 15, 2013 #4 ericttype said: cam sensor tool casper $35.00 used coil pack & module working order $75.00 used a/c lines no holes good shape $125 snew J&e stroke pistons 5.970 rods with rings $525 Click to expand... cam sensor & coil pack sold TTT
E ericttype Member Joined Nov 22, 2009 Apr 6, 2013 #5 ericttype said: cam sensor tool casper $35.00 used coil pack & module working order $75.00 used a/c lines no holes good shape $125 snew J&e stroke pistons 5.970 rods with rings $525 Click to expand... NEW j&e stroker pistons with file fit rings $450 paid over $750 for 5.970 rod 3.625 crank
N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Apr 7, 2013 #6 A few questions: 1. Exact bore size for the pistons? 2. What size pin, and is it standard or upgrade in strength? 3. What brand rods? 4. Make and type of rings? Thanks.
