Cam sensor adjustment ?
BLACK Ttype
Getting Respectable!
I installed a new cam in my car. when I put the cam sensor in, I followed the directions herehttp://www.gnttype.org/techarea/ecmsensors/camsensor.html
All was good untill,
the voltage dropped like it was supposed to but when I went to tighten down the bolt, the screw that holds the cam sensor cap is directly over the bolt that holds the cam sensor down.
Any ideas or opinions?
Move it.
Remove the sensor ....take a long screw driver and turn the oil pump "slot" a bit, put the sensor back in, lining up the bottom of the sensor with the new location on the oil pump and have at it again.
