boostedblkbeast
- Oct 20, 2003
I have been reading about how important cam bearing alignment is to the oil passages in the block and that if they misaligned this will toast your new motor before you know it. I am asking because I just got my block back from the machine shop and I see that the number 1 cam bearing is aligned, but the other 3 are not aligned with any oil passage in the block. Are there oil passages built into the block in the other 3 cam bearing locations, or is just having number 1 aligned the only thing to worry about. If there are no other oil passages besides number 1 cam bearing, then why are there openings in the cam bearings as if there are passages thier. Or should the other 3 be aligned with an oil passage to maintain proper oil pressure. I just don't want to kill my motor before I get to enjoy it. Thanks and any help really apreciated.
