109 block fully machined with program engineering 4 bolt steel main caps
stock riods with arp bolts, shotpeened and polished beams
stock crank stanard on the journals and balanced
block crank and rods have been cyrogenically treated
clevite bearings
je turbo pistons
hellfire rings
comp cams hydraulic roller cam with comp lifters and pushrods
brand new gm timing cover with high volume oil pump and all oil passage have had any casting flash cleaned up
stock steel heads ported by kenny dutweiler with oversized stainless valves
t&d shaft rockers
buick racing aluminum valve covers powdercoated black with k&n filters
stock aluminum intake also ported by kenny dutweiler with stock ported plenum and throttle body
stock dampner and flywheel
shortblock has 200 street miles on it everything else is brand new never fired
5500.00
clevite bearings
je turbo pistons
hellfire rings
t&d shaft rockers
5500.00
