Need information and feed back soon as possible with the CP Pistons that i am using for my stage 2 motor.My problem and concern is the clearance between the bottom of the piston and top of the Carrillo 6.5 on center rod. I took pictures so you guys can see if i will be running into problems with the piston hitting the top of the rod.How much clearance should i have in this area because there is more clearance on one side of the rods than the other side thanks for your guys help.
