Broken down outside Bakersfield.
notacarlo
eggs are liquid chicken
If anyone is near Bakersfield CA and you have some time, my uncles 6.0 blew the egr cooler. He's making the trek back to Dallas. He has a 30' boat that needs to be towed to the shop where the truck is being repaired. Any help would be greatly appreciated. He's a great guy.
Stew Foster 214 213 5039
Dan
It cools the egr.
Ford (in all its wisdom) put a pipe inside a pipe. One with hot exhaust gas and the other with coolant from the radiator. The internal exhaust pipe ruptures and allows coolant into the exhaust stream preturbo! Common issue on the 6.0.
:) truck doesn't pull a boat so well in the California mountains like this. Plus the coolant is gone, causing overheat.
He's still out there and needs help.
Call Brian at Hovens automotive. Ford superdutys are his specialty great and honest guy! (661) 326-8455
Did you try PMing Mike to see if he had someone out there? BTW, will your Uncle admit being related?:ROFLMAO:
