Had new Brembo rotors delivered earlier this week, and when I started to put the wheel bearings into them, there are already bearing races pressed into the rotors, both inner and outer. Is this normal? Should I use them, or remove them and use the races that came with the SKF bearings? It sure would make things easy if I can use the races that came in the rotors.
