Bryan Weber
- Jan 19, 2005
Weber Racing Equipment now has brand new 109 blocks, Timing Cover Kits, and 763 Connecting Rods for sale.
There is a limited supply of these parts and once they are gone that's it. We bought all the inventory so I know there is no more. Get one while you can!
New 109 SG1 Block:
These are brand new individually wrapped and boxed GM 109 SG1 blocks that have never been in use. They are finish machined other than a finish hone on the cylinders and the oil drainback hole will need to be drilled and tapped. These are not defective or blems in any way.
New Buick 3.8L 109 Engine Block
New GM standard volume timing cover/ oil pump kits:
We have brand new GM standard volume timing cover/oil pump kits for the rear drive 3.8 -4.1 Buick V-6 engines. These are the real deal not a cheap imported knock-off. The kits come with a GM timing cover w/ original GM rope seal and retainer, metric pump cover with by-pass, pressure regulator and bolts, flame hardened gears, and gasket. The aftermarket covers can't hold a candle to these!! We have the kits that are unassembled Brand New GM 3.8L Buick V6 Timing Cover Kit and we have a fully ported and blueprinted version
New GM 763 casting Connecting Rods with SPS bolts:
Brand New individually wrapped and boxed in sets of six connecting rods just like what came in these turbo engines from the factory. At this price it does not even make sense to recondition the old used rods that came out of the engine. Brand New 3.8L Turbo Buick GM Connecting Rods
New 109 SG1 Block:
