Quick refresher. I'm installing my adjustable proportioning valve in the rear brake line. As a matter of course, drained all the fluid out of the rear brake reservoir and uncovered the port (front reservoir). When I put it all back together, I need to get the air out of the PM first which I can do by putting fluid in the reservoir closing it up, having a friend depress and hold the brake, cracking the rear brake fitting at the PM letting the air (and some fluid) escape. Do that a couple of times for good measure. Then bleed the four wheels like normal.
Sound right?
Thanks in advance,
Matt
Sound right?
Thanks in advance,
Matt
