8 83 regal Member Joined Aug 21, 2008 Jun 16, 2010 #1 right side rear brake is locking up when applying brake.
G gusszgs Active Member Joined Dec 9, 2007 Jun 16, 2010 #2 Pull the wheel and drum and check for leaking wheel cylinder or possible wheel bearing seal leaking and contaminating the brake shoes.
8 83 regal Member Joined Aug 21, 2008 Jun 16, 2010 #3 no fluid leaking.e-brake cable has kink in it .
T tzque Member Joined Jun 26, 2006 Jun 21, 2010 #4 Replace the rubber brakes lines to the caliper before you do anything else . They swell and create locking up issues
