I'm getting the rear brake lights working some time, the third light is working all of the time. The brake switch has two plugs. one has three wires: orange Hot, white, and blue/black tracer. the blue/black goes to the rear brake lights ( i think ) the switch is working, i'm getting a test light every time to the blue/black wire, but some times no rear brake lights.
The other two wires brown and ??? i do not know were they go from the other plug.
Could there be a bad ground back at the rear ?? On the wiring diagram shows a ground for each light. where is the ground wiring located.
The turn signals work ok, the running lights are ok, just the brake lights.
Any ideas ????
Any ideas ????
