Brake Light with Vaccum Conversion
josefigue
Hi; I change to vacuum conversion.I put new booster,new master cylinder,new calipers,new hoses and stainless lines,new rear cylinders and distribution valve.I bench bleed the master cylinder and bleed four corners twice.The brake light its on.What can I do? Please help.Thanks::(
How does the pedal feel? When you bled them did you do them in this sequence, RR,LR,RF,LF sometmes it will take a bit of bleeding to get all of the air out of the system.
