Yes, but it doesn't like much bending. Kink it and it will leak! I would avoid it unless you are willing to buy the needed angle fittings which can get expensive.
If you want your car to smell like fuel for the rest of your life use the standard braided stuff, if you don;t then use teflon. It takes more heat and is still pretty flexible, but don;t go crazy with the bends. Iv'e had good results with frozenboost stuff, but it is china stuff, but its not bad.
I did my whole fuel system with it, feed -8 and return -6 with Aeroquip TFE (teflon SS braided). I'd do it again. I've heard you can get the same stuff at hydraulic supply shops to save money over premium brand names.
