Boost Levels Turbo SBC
KWIKR 1
what kind of boost levels are you turbo SBC (8.5:1 CR) guys running on pump gas ? Just got my Tial wastegates in and they shipped them with a .70 Bar (10 psi) spring . I maybe mistaken but I'm sure I ordered them with a .40 bar (5.8 psi) spring . thanks
Thanks guys . I guess if that's the case I should be ok with the 10 psi spring . :) I suppose the closer the spring rate setting is to your desired boost pressure, the less work your boost controller has to do.
