FASTV6HENRY
- Feb 16, 2012
I did a search, however could not find anything regarding my question...i was wondering if the size of the line used for the boost gauge makes any difference. Reason i ask is because the autometer cheap plastic clear tube line kinks very easy and was thinking of using a larger 7/32 regular rubber vacuum hose…I also is the signal form the MAP sensor any different from the signal coming out of the evac canister. The canister was closer and would be a cleaner install….
thanks
thanks
