I've searched and found a lot of info on the BMS cranks here, but there really isn't a thread devoted to talking about them.
There are pleny of reports of failures, and a few people that make good power with them. There is usually very little info posted about the condition of the crank before the breakage. There is no way to put a definite limit on one, but having real world experience can help people make a better judgement about how far to push one.
For the guys who have had one break.
What was the condition of the crank when you put your motor together? Freshly machine forging.
-Used drag only.
-Used good condition round track.
-Repaired (welded, hardchromed).
When did it break? street cruising, burnout box, top end of the track.
How much power?
What stroke?
What Rod Journal Diameters? Standard, undercut buick sizes,2.200bbc, 2.100 sbc
Wide Journal or not?
If you suspect it broke becuase of an issue outside the strength of the crank, then what? Can the breakage be attributed to a bad tune, hydrolocking, detonation, spun bearing, oiling etc.
If you have pictures of the crank after broken that would be nice. A picture of the fracture surface can tell a lot about how and why it failed.
Same questions for the guys that have had success with one?
-Used drag only.
How much power?
What stroke?
