Jeff -
I am running a stock pump with a booster plate. I have a PT&E turbo saver and a 3 plate EOC in the rad (ie bigger than the stock EOC). Did lots of porting to the oil passages in the timing cover and the block. Oil filter bypass is plugged in the oil pump cover. Cam has the groove in the journal, would have liked to had it welded up, but didn't. Running TA Perf's cam bearing in the #1 spot because I had too much wear with an aftermarket replacement (not sure what brand that one was). The TA Perf cam bearing only has one oil hole for #1, located about 4 o'clock in my installation. I run 10W-30 oil, and at hot idle (750 rpm programmed, also got a 180F thermo, gotta change that one of these days) I see 20 psi during the summer, 25 psi right now. At 55 mph I see a tad less than 60 psi, at 60+ mph I see 60 or a bit more. Not sure which spring I have in the relief valve. Oil pump end clearance is 0.002" I think, could be a bit more. I spent a long time trying to get it tighter, but everytime I did it would bind a little when I turned it by hand. Idler gear has a hole drilled in it. Gears themselves are standard auto parts store units, nothing else special done to them. Engine is fairly fresh rebuild, not sure of the miles I have on it now, less than 10k that's for sure, so I can't report on the long term effects of any of that. I can say that the #1 cam bearing installed by the machine shop had a lot of wear for the short time it was in there, glad I swapped it for the TA Perf one. I think I loosened up the oil pump clearance a little at that time too. I spent way too many hours on that thing... That's everything I can think of.
John
