I have modified my motor (see avitar) to be used with a MOROSO belt driven oil pump, a chevy style twin oil filter kit,RJC 's deep sump oil pan,and a rather large oil cooler. (factory oil cooler in radiator will not be used)
I am planning to use mobil synthetic 20w-50. Oil pressure is variable on pump.
Motor is freshly built with internally balanced FORGED EAGLE CRANK,FORGED H-BEAM RODS,FORGED SPEED-PRO PISTONS,and a BILLET ROLLER CAM KIT. Block is .030 over and heads are currently stock w/stock rocker arms.
This motor will be driven daily on the street and occasionally on the track.
I have heard that high oil pressure will cause problems with the cam sensor,but this will not be an issue for me on my setup.
My question is what would be a good oil pressure for this setup?
all input is appreaciated in advance THANKS.
