First time motor had the girdle. I got about 1500 miles on it. Oil pressure was up and down, cut filter found bearing material. Turned out to be a cracked crank, main bearing 2 & 3 burnt. Found also one cap was cracked. Turned out block was machined down on pain rail,front cover and caps were cut also, but evidently cut too much, so I needed new caps and can't use the girdle on this block now. So no girdle this time. Block was honed and line bored and crank was checked.
I am not exactly sure what was measured and what wasn't by the machine shop. I have had this work done by someone else. So I am just trying to gather other opinions and try to learn. Thanks
