Originally posted in GMHighTech
Jack Merkel Performance Engines performs many mods for the unique needs of the Buick turbo V6 engine. Due to its rather unorthodox oiling system, the engine has some unique bearing clearance needs. "Common small-block Chevy thinking manifests itself by allowing too much bearing clearance. This works fine for the SBCs, which commonly spin 6-, 7-, or even 8-thousand rpm. But the Buick motors usually spin 5200-5600 rpm max. They have very high cylinder pressures at low rpm and can produce in excess of 600 lb.-ft. of torque under 3000 rpm. If the main bearings are hemorrhaging oil pressure at low rpm, the rods are going to be in an oil starvation situation. They will overheat and this will cause a spun bearing," explains Merkel
Merkel likes to see no more than 2 thousandths clearance (1.5 is preferred) in the main bearings due to the fact that there are no 3/4 groove main bearings available for Buick V6s. (We should note here that 3/4 groove bearings should be available from Federal Mogul by the time you read this.) Oiling for the rods is very important in a Buick because six rods are doing the work of eight. Merkel says, "These engines don't see a lot of rpm so the important thing is to keep the main clearance tight to ensure adequate oil volume to the rod bearings. Typically a small-block Chevy will run a higher rpm to produce the same horsepower on the motor, so they need more clearance."
