onefastjackass
- Oct 6, 2002
Ok MY battery is draining while sitting will not start after a few days.I unhooked the battery for three weeks and then it dosn't drain and cranks over fine.
Car runs fine and doesn't lose electrical power while running.
So this leads me to believe that the car is the problem not the battery.While hooking the battery back up I also noticed that a clicking was coming from a relay on the drivers fender the one that has two cannon plugs going on it.
If I disconnect the inboard one (farthest from the fender) the clicking stops.If I disconnect the other one(closest to the fender) and put other one back on(farthest from the fender) then it clicks.
What is the relay for and what would be keeping it energized?
Also the car has a hot wire kit and also a volt booster along with all the things listed in my sig.Any thoughts or ideas would be appriciated. Thanks Kevin
