make sure you jack it up from the lower control arm before checking. dont jack it by the frame .The suspension has to be loaded while checking. grab tire at 12oclock and 6oclock and move the tire in and out while watching for movement. or put prybar under tire and pry up on it and see if there is any movement. shake side to side also to check the idler arm and center link.
