I have been chasing around a 15 lb boost knock and I am at the end of my rope. This is an 87 GN with 59,000 miles. I is stock except for 30lb green stripe injectors and an ultra chip.
Scan readings are good. Changed the coil pack, fuel pump,fuel filter, hot wired fuel pump,tightened all grounds,cheched battery cables and ends.
Ihave been playing around with fuel pressures from 34-44 psi. I have the best success with 38psi,the scan readings are ok but i still have knock above 15psi of boost.
I noticed the idle is getting a little rougher but not like an ignition miss.
Could this be a symptom of a cam lobe starting to wipe? If it is what lobe usally wipes? Anyone have any ideas?
Thanks Steve
Thanks Steve
