What's the point of having a GN if you can't accelerate? Its been going on for about 1 1/2 yrs. and appears to be getting steadily worse. Normal driving is fine. If I go over about 1/4 throttle the car backfires and I have to let off. Can you say Embarassing? It doesn't do it everytime. I've changed the coil, wires, ESC, ignition module, knock sensor and ECM. The EGR and solenoid are new but deleted via champion irons. Ground wires are tight and all vacuum lines new. No malfunction codes appear on the Scanmaster. Any help with this intermittent backfire is greatly appreciated. Joel
