back up lights
hangontight
Back up lights come on when car is put in neutral instead of reverse, where is the adjustment made to fix this?
I would say it would likely be an adjustment in the linkage to the column. the adjustment point is right by the shift linkage arm on the transmission.
Assuming this is a floor shift car the linkage from the trans to the steering column may need adjusting. If you have to adjust the switch it's located on the steering column near the base on top.
back up lights fixed
Thanks Guys,
The link supplied by Thecatman was right on. I loosened the bolt on the cross rod underneath the car and moved the linkage until reverse light came on, then re-tighten bolt, very easy.
With the help of my 11 year old son it was done in 5 minutes. Thanks again
