Axles
I have a set of moser 28 spline axles , HD wheel studs , and moser c-clip eliminators
for sale - only have 1500 street driven miles on them and no track time
im looking to get 175 + shipping for them
So the axles already have the eliminators on them and all i would need to do is prepare the Housing like this says( I got this off the Mosier web site)...
1. Remove brake backing plates and bolts from the
housing end snouts.
2. Remove the stock bearings and seals from the housing end snouts.
3. Using a hacksaw, shorten the snouts to 1/8” (See Figure B). Then,
using a file, deburrthe rough edges of the hacksawedsnouts.
4. On some brake assemblies, the brake spreader bar may hit the top of the
eliminator. If it does, simply tap the spreader bar so it has a slight arch in it.
5. Re-install (Slide on) the brake backing plates.
6. See attached sheet for additional housing preparation for G-Body/Metric applications
housing end snouts.
Had a local shop install them for me - but that's it
